Re: how to try out Torque amplifier?
Posted by rustred on May 27, 2011 at 20:29:38 from (74.200.18.155):
In Reply to: Re: how to try out Torque amplifier? posted by realolman on May 27, 2011 at 17:57:17:
think of it this way. the only time the ta is to be used is when your running out of power plowing or deep tilling , when your think you need to down shift you pull the ta then once through the tough spot you go back to direct. even for baling hay it is handy. thats what it was designed for. not to be used just because you want to. no reason at all to use a ta on the road. unless maybe pulling a heavy loaded hay wagon up a hill or some thing like that.in other words forget you have a ta and when you actually need it it will be there.what tractor is this on?
