Re: Cub Plug Wiring
Posted by El Toro on May 28, 2011 at 14:38:39 from (108.15.86.54):
In Reply to: Cub Plug Wiring posted by equeen on May 27, 2011 at 18:15:56:
If you removed the distributor did you bring No1 piston near the radiator to TDC on the compression stroke before installing it? Hal
