I think anything is possible, but that is not (opinion) a modular plow. To remove the last Bottom (the share is the cutting surface along the lower edge of the mold board, the bottom is the entire turning unit.) Noting exact location of all parts welded, and shortening systems and linkages, rewelding all parts, and making it work is doable if you are a fabricator, or friends with one, or have as much money as needed. Trading it might be better, but big turning plows are not in demand due to modern practices in most locations. Jim
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
