Re: Is this the plow you can remove a shear?
Posted by toolz on May 28, 2011 at 21:05:15 from (206.221.154.149):
In Reply to: Is this the plow you can remove a shear? posted by kennell on May 28, 2011 at 18:11:02:
Not too bad of a job- just remove the last bottom assembly, shorten the main beam and steering rod, and bolt the tailwheel stuff back on. It looks like a 550, and 2K is about 4 times what it's worth. A little more if all the wear parts are real good. I sold one about 2 years ago for $200 (I think) to a friend, he made a fast hitch 4 bottom out of it.
