Not at home right now. I did get the clutch cover off, as posted in my other thread. took 2 pecks of mouse nest out, and the reason the egnine wouldn't turn over was the crap had rusted the flywheel to the bottom of the clutch housing. got that cleaned out and everything turns over real nice.
I can't remember the exact serial number off the top of my head, but I know it was made probably around November 1928, so will be close on the serial number switch over.
cowman, I will send you an email, as I will need the clutch, pressure plate, and shaft. The splines are really worn where the coupler yoke goes on, so might as well replace that too. do you have both types of clutches in stock? I really don't want to pull the flywheel unless I absolutely have to. I think I can dress the existing one up a bit after I get the clutch off.
This one is going to be just for show, and won't be doing any heavy work, might pull a wagon or run a buzz saw from the belt.
Oldiron29, I 'll post more pics tomorrow when I get home.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
