Re: Adding remote hydraulics to a Super C
Posted by mkirsch on May 29, 2011 at 05:18:42 from (67.253.161.186):
In Reply to: Adding remote hydraulics to a Super C posted by riverbend on May 28, 2011 at 18:37:34:
Tapping off the plugs won't work right.
The Super C has an open center hydraulic system, which needs a single path through the system to work properly. Connecting a valve to those ports adds a second path to the system, so when you try to run the arms, the oil will all flow through the valve circuit, and when you try to run the valve, the oil will flow through the arm circuit. Either way, nothing will happen.
You need the bypass block to make it work right.
