Posted by El Toro on May 29, 2011 at 07:49:38 from (108.15.86.54):
In Reply to: 230 shutting off posted by 400Dtractorman on May 29, 2011 at 07:31:22:
When it quits running check for fire to your plugs asap before it cools. If you have good fire to your plugs its probably a fuel issue. Pull the gas line at the carburetor and see if there's a full stream of gas from the tank. If that looks ok remove the tube fitting where your gas line connects and look for a screen that may be plugged. If the screen is clean you probably need to pull the carburetor and soak it in carb cleaner after disassembly and blow out the jets with air. Check the float setting too to make sure it's set at the right height. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
