Re: Is this the plow you can remove a shear?
Posted by The tractor vet on May 29, 2011 at 08:17:35 from (76.212.227.102):
In Reply to: Is this the plow you can remove a shear? posted by kennell on May 28, 2011 at 18:11:02:
Yep you can cut them down to a three bottom as i have done many . Just remove the tail wheel and shorten it up and reinstall the tail wheel and shorten the coupling pole . When done correctly they will plow like they should , done wrong they will never plow wright again .
