Re: Super C steering
Posted by Haas on May 29, 2011 at 17:06:04 from (75.201.187.155):
In Reply to: Re: Super C steering posted by Joe P. on May 29, 2011 at 11:38:03:
Top plug is the fill, bottom is the drain and the middle one is the oil level. Fill till oil comes out the middle hole. I've rebuilt a couple of these and if you put in a new seal and if the vertical shaft is worn, use a speedy sleeve or have a machinist repair it so there is a good surface for the seal, it won't leak oil out.
