Re: Carb?'s Brake ?'s 1955 300U
Posted by Trucker101 on May 29, 2011 at 20:19:12 from (74.214.146.252):
In Reply to: Carb?'s & Brake ?'s 1955 300U posted by CNKS on May 29, 2011 at 18:39:06:
CNKS said: (quoted from post at 18:39:06 05/29/11) #3 is the main jet adjustment. Full power is 5 turns out, can be turned in 1.5 - 2 turns or so for light loads. Disk brake mechanisms are easily removed by removing the 5 bolts. Diagrams are in the parts book or in the parts section of www.caseih.com.
Oh okay, then on the other side of the tractor where the fuel bowl is.The valve that you open to let the gas flow, how much should that be open? If I open it 1/4 turn there's a nice steady flow of gas. But if I open it 1/2 a turn the flow slows to a dribble. Is there something wrong here or is that normal? And thanks for the link. I printed off a lot of stuff.
This post was edited by Trucker101 at 20:20:27 05/29/11.
