Posted by Jimb2 on May 29, 2011 at 20:25:10 from (99.240.236.11):
In Reply to: IHC 484 posted by Martin Reece on May 29, 2011 at 17:46:55:
Hi, the sending unit on top of oil filter housing should produce a ground when there is no oil pressure. With the switch on, take the wire off the sending unit and touch the wire to a clean spot on the block and the oil light should come on.
Had the opposite problem on a 684, oil pressure light came on while chopping corn. Scared the Sh*t out of me but sending unit switch was bad. JimB
