706 gas oil pressure light
Posted by jd plowboy on May 29, 2011 at 20:33:51 from (166.166.27.190):
we got a 706 gas with a 263 in it. when you press in the clutch pedal the oil pressure light blinks off and on. could it be cause from the switch that is mounted behind the clutch pedal or could it be the switch on the TA valve on the side of transmission housing. it only blinks when the clutch is pressed in.
