Re: 884 not charging
Posted by richardinnz on May 30, 2011 at 04:29:06 from (125.239.171.93):
In Reply to: Re: 884 not charging posted by GRB54 on May 29, 2011 at 20:22:16:
The IND lead (small wire) when removed from the alternator and grounded should make the dash lamp come on when the key switch is in run position..
The fat leads should be connected straight back to the battery (usually at the starter terminal)
The black plug on the back of the alternator can give trouble and can be dispensed with and spade terminals pluged straight into the back of the alternator
