Re: 1586 clutch, trans, problems
Posted by dieselbob on May 30, 2011 at 06:24:46 from (64.72.184.147):
In Reply to: 1586 clutch, trans, problems posted by MNHighwired on May 29, 2011 at 21:49:52:
Hi Back in the day when I was running my shop it was always that ? So it was standard practice to remove the cover on the third arm for inspection youcan see the diff have some one run the tractor the see if the diff turns if it does then jack up one side at a time and turn the wheels by hand and listen they turn hard if diff doesn't turn then it could be clutch hub you can drop the bottom cover from the ta housing to see if any thing turns. That is one thing about IH tactors is you can take a lot of covers off to see what is wrong. One more thing run a magnet through the oil in the trans case to look for clues. good luck on your quest. Bob
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
