Re: 300 clutch and brakes
Posted by chris in tn on May 30, 2011 at 16:10:57 from (96.38.35.2):
In Reply to: Re: 300 clutch and brakes posted by Kingston Kid on May 29, 2011 at 20:47:45:
Pulled the brakes off, had a lot of grease in them, I am guessing from leaking brake shaft seals. One of the springs was broken also.
The inner discs against the transmission housing are still on the brake spindles. From what I have read here they can be wedged off carefully using a pry tool. Is the oil seal then accessable to simply be removed from the outside and another pressed into place? The IH parts diagram looks like there is a retaining clip and a couple seals there so I"m not sure-
Pulled the clutch inspection plate and all I could see looks to work ok, so I guess it's got to come apart. Anyone here ever posted a how-to on splitting one of these 300s with hints and tricks?
