Farmall b conversion
Posted by cuttman on May 30, 2011 at 16:27:09 from (184.1.107.185):
I know there are several posting on this but, I am trying to wire a farmall b tractor to 12 volts. I have a 10SI 3 wire alternator, ammeter, toggle switch, starter and battery as parts and no ignition switch. They evidently used the toggle for the on/off switch. I need somebody to tell me how to run the wires using the parts as there is no wiring there now. I have another toggle switch that is the kill switch for the magneto that works. The battery is setup for neg. ground.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
