Re: F-30 cooling
Posted by DeltaRed on May 30, 2011 at 21:33:52 from (97.124.213.236):
In Reply to: F-30 cooling posted by SB in IN on May 30, 2011 at 21:28:57:
Put a thermostat in it.If the factory thought it needed a t-stat,it probably does.
