Re: Super C steering
Posted by Mason in CA on May 31, 2011 at 00:08:16 from (98.207.194.4):
In Reply to: Super C steering posted by Joe P. on May 29, 2011 at 10:56:20:
Exactly what these fine gentlemen are saying... i just finished my restoration of a 51' Super C and i had the same head scratcher. But i figured out after i put the worm gear back in and replaced the back oil seal that it filled from the top and the in between was the fill level. I myself used 90 wt in there, and everything is working perfect for me.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
