Posted by Nebraska Cowman on May 31, 2011 at 03:27:55 from (66.252.115.12):
In Reply to: F-30 cooling posted by SB in IN on May 30, 2011 at 21:28:57:
No, I don't think it would be smart to block the by-pass. The water has to go somewhere. The bypass is so the water has a place to relieve the pressure when the thermostat is closed. Without a thermostat the water can go straight through. You will not have trouble overheating. IF you wanted to run the tractor in the winter and wanted it to warm up you could cover or partially cover the front of the radiator regulating the temperature yourself. Thats what the thermostat does.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
