Re: MD fuel needle adjustment
Posted by sflem849 on May 31, 2011 at 04:14:02 from (69.197.84.78):
In Reply to: MD fuel needle adjustment posted by sflem849 on May 30, 2011 at 19:25:59:
There is no description of how to adjust the needle in the starting lever adjustment section. I didn't look at the carb section when I did the starting lever adjustment. I started at the head and worked back to low idle so I would have done it somewhere in there.
When I put it back together the first time I know the needle was seating relatively well the first time because the sediment bowl would only fill with a drip when the lever was in diesel. When I put it back together after doing the head it didn't seem to shut the gas off as well. Maybe I will pull the carb. :? It likes it's choke anyhow so it could use a cleaning.
