Posted by John T on May 31, 2011 at 05:26:16 from (173.243.189.183):
In Reply to: 12 Volt Generators posted by sven on May 31, 2011 at 05:01:29:
The old 6 volt system may have had a Cutout Relay versus a full fledged (3 or 4 terminal) Voltage Regulator as on the newer 12 volt system. Regardless, a cutout relay is necessary, whether a stand alone cutout relay (works between BAT and GEN/ARM) or as still present in a newer VR, to open the circuit from BAT to ARM/GEN when the tractor is shut down otherwise the battery reverse discharges rapidly and the genny overheats.
If you convert from an old cutout relay to a newer VR, the gennys FLD no longer wires up to the dash to a LHBD switch, it now wires to FLD on the VR
BAT on VR up to load (NOT battery/starter) side of ammeter
ARM/GEN on VR to gennys ARM post
FLD on VR to gennys FLD post
LOAD (if it has one) wires to the BAT input terminal on the light/ign switch
Id polarize the genny BEFORE starting
If you switched from Pos to neg ground, the ammeter leads need reversed as well as the coil if it had a coil instead of a mag ignition that is. With a mag no changes required or wiring used other then a posible grounding kill switch
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
