Re: Before re-installing my motor what should I do to the...
Posted by Bill in NJ on May 31, 2011 at 05:47:01 from (4.248.91.101):
In Reply to: Before re-installing my motor what should I do to the tranny posted by GRAPE-DRANK on May 31, 2011 at 04:38:39:
As long as you have it apart you should do the following. First thing I would do is clean the inside of the bell housing. Second, if clutch disk and pressure plate need replacing, do it now. You should also install a new throw out bearing. That's the thing that looks like it is cherry red in the pic. Check the transmission input shaft seal. If it is leaking, replace it. Put a thin film of grease on the tube the throw out bearing retainer rides on. After it is all together, grease the throw out bearing. There should be a grease fitting on the bearing carrier. While reassembling, be sure to inspect, fix and lube all the clutch linkage.
