Posted by harpo on May 31, 2011 at 06:22:46 from (63.254.148.120):
In Reply to: Farmall h posted by volkswagen on May 30, 2011 at 19:28:34:
All 3 outlets have equal pressure and flow volume. If you are talking about the delay lift for the rear gang of a cultivator, the delay lift valve goes in the hydraulic line. It is a spring loaded devise that only opens with a set pressure.
The front gangs do not take a lot of pressure to lift them. After they are up all the way the pressure builds because the cylinders are fully extended and then the delay lift valve opens and the rear gang raises.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
