The vertical lift links from the rockshaft are supplied with a cast iron shaft collar and a large square headed set screw. There are three positions for the set screw about 2" apart. This allows for no float or as much as 6". Perhaps one can remove the collar and get even more.
There are also pins with D-rings on the fast hitch sockets. They can be removed, stored in another hole on the receiver, and this permits the Fast Hitch receivers to rotate as much as 30 degrees or more.
So, yes, there is float capability on the later Fast Hitch. I am guessing all Fast Hitches after 1955 can float in this manner. The previous Fast Hitches can float by removing one pin on the vertical lift link.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
