Re: torque specifications
Posted by Phil Auten (TX) on August 03, 2000 at 04:12:11 from (206.175.72.226):
In Reply to: torque specifications posted by STEVE KRUK on August 01, 2000 at 19:28:35:
Steve, Check out the site linked below. Go to Torque Specs in the Research section. It has everything except the torque sequence. I just start with the bolts in the center of the head and work outward in a spiral pattern. Torque to about 2 thirds of final value, then add half the difference and torque to that and then on the third pass torque to full value. Example: if the final value is 60 ft/lbs torque to 40 ft/lbs, then go around again torqueing to 50 ft/lbs, then make a third pass going to 60 ft/lbs. Retorque after running up to full temp and cooling down and retorque again after running for a few hours. If any fasteners don't hold torque, replace them.
Good luck,
Phil
Post A Followup
: Re: Re: torque specifications
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
