Re: 86 series IH tractor rear frame pump gaskets
Posted by RPM1941 on May 31, 2011 at 10:07:55 from (173.25.71.175):
In Reply to: 86 series IH tractor rear frame pump gaskets posted by charles donaldson on May 30, 2011 at 15:41:03:
The casting might be not milled flat on one of these but not both, put a straight edge on the housing vertically, was thinking that this happened on 66 series more times. The oring should be a class 5 rubber or above. You might try a teflon (the blue hard rings) inside & outside also. This would happen on the tractors with 2250/2500 psi system relief cartridge more times also.
