Basically nothing to adjust. It is kinda spring loaded.
It running rich is making sense now. Definitely pull the carb and check the seat. It is pushed closed in diesel so even a bad float isn't an option.
Where fuel line comes in at the front side of the bowl there is a little cavity in there. The fitting itself should have a screen attached. For one, the screen fails. For two the cavity also fills with crud from the starter tank. The crud drifts upwards towards the seat and can muck it up. The setup is very tolerant of debris, but limits are limits. Make sure the whole mess is clean.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
