Posted by Theman on May 31, 2011 at 14:51:24 from (65.198.133.254):
In Reply to: Farmall h posted by volkswagen on May 30, 2011 at 19:28:34:
From what you describe, the broken spring is a counterbalance and that very well could be the problem. To eliminate the possibilities, I'd disconnect the rod of the non-moving cylinder (don't let it fall - block it up) and make sure the cultivator linkage/mechanism isn't in a bind. Then check to see if the cylinder will extend without a load. If it doesn't extend, you may have a plugged or collapsed hose, or the cylinder itself has seized. Being a one-way system, you know the cylinder isn't bypassing or it would be leaking oil.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
