Re: Before re-installing my motor what should I do to the tr
Posted by oldtanker on May 31, 2011 at 16:35:23 from (66.228.255.223):
In Reply to: Before re-installing my motor what should I do to the tranny posted by GRAPE-DRANK on May 31, 2011 at 16:16:58:
IPTO is independant PTO (live plus dirves the hydraulics on newer tractors) which you don't have, my mistake. The tranny input shaft you do have. That's the splined shaft that is in your photo. It has a seal on it where it goes into the tranny. While it's apart I would replace that too.
Splitting a tractor isn't the best job in the world and unless you enjoy splitting one I'd fix everything in there I could afford to. I'd also repair and replace anything that needed attention while the sheet tin is off too. Just make it easyer to work on.
Rick
