Re: Ice on the carb of my 656
Posted by Tom Fleming on May 31, 2011 at 18:15:28 from (67.20.243.240):
In Reply to: Ice on the carb of my 656 posted by Josh Day on May 31, 2011 at 16:56:52:
The venturi in the carb restricts the fuel/air passage then expands quickly on the manifold side. This accelerates the flow of air, then when it suddenly is no longer constricted on the opposite side of the venturi, the fuel vaporizes. It takes heat to vaporize the fuel, and subsequently the upper part of the carb, where the venturi expands, cools down as fuel evaporates, as heat is being drawn from the carb/venturi body........hence the condensation, and finally ice. Normal operation of that type of carb.
