Re: Farmall Super A motor rebuild.
Posted by GRAPE-DRANK on May 31, 2011 at 19:14:37 from (98.117.64.170):
In Reply to: Farmall Super A motor rebuild. posted by gene bender on May 31, 2011 at 18:22:14:
So let me get this straight:
I don't have to use a water pump if I don't want to with this block?
If I get a water pump I have to get a thermostat.
If I get a thermostat the outlet will be bigger and I have to get a different radiator?
