Re: Ice on the carb of my 656
Posted by old on May 31, 2011 at 19:27:20 from (209.86.226.34):
In Reply to: Ice on the carb of my 656 posted by Josh Day on May 31, 2011 at 16:56:52:
If it did not do that then you would have a problem. But since it does then things are working just as they should be doing. A car or truck would do the same thing but they have a tube going form the exhaust manifold into the carb air cleaner so warm air goes in and that in turn stops the icing. So yes I am saying it is normal and the way a carb works. Just like it you compress air the air gets hotter and when you let the air out if you do so fast enough you can cause water to turn to ice from decompression of the air
