Re: Farmall 1206 TA
Posted by Janicholson on June 01, 2011 at 06:13:04 from (64.61.211.231):
In Reply to: Farmall 1206 TA posted by andy stockmaster on May 30, 2011 at 16:58:10:
From reading on this forum, The first thing I would check is the cable linkage from the lever to the control valve. These have had issues, and are easy to repair externally. The fluid pressures on the TA are either applied to the direct clutch (Higher speed), or the TA locking clutch (holding it in TA)
if it free wheels when operating (speeds up down hills as though in neutral) I would suspect an MCV hydraulic issue.
If it does not free wheel I would suspect linkage issues to the valving. The Vet knows much more than I on this issue. Jim
