My SA was built in early '49. First time I had to take the head off, I went into the dealer for a new head gasket. He asked me if it had a water pump or not. I said "no" and he brought out a different gasket than I took off. Turns out the gasket for my engine had larger water passage holes so there was no resistance to the thermal flow. The gasket for the water pump type engine had small passage holes, to give the pump some resistance I guess. Who ever had this tractor before I got it put in the wrong the wrong gasket. I put the correct one in with the larger holes, and noticed that it did run cooler. You will see two part #'s in the part book. If you use the water pump, you need the head gasket with the smaller holes.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
