Re: 86 series IH tractor rear frame pump gaskets
Posted by RPM9141 on June 01, 2011 at 09:38:33 from (173.25.71.175):
In Reply to: 86 series IH tractor rear frame pump gaskets posted by charles donaldson on May 30, 2011 at 15:41:03:
This is strange, I have not ever had this quirk, these systems are the same from 706 to 1586 basically, sounds like a plugged filter or Hytran dirty, is this a gear pump style or PFC piston pump, a series of these 86 only were made, IH finally told us to convert to gear pump. Filter quality issue maybe, they made some hi filtration for clean-up but needed to be changed after short time. I was in IH/CNH service for 47 years , not sure what to tell you.
