Re: Farmall Super A will a 1954 Super A motor swap into a...
Posted by GRAPE-DRANK on June 01, 2011 at 12:03:03 from (98.117.64.170):
In Reply to: Farmall Super A will a 1954 Super A motor swap into a 1949 posted by GRAPE-DRANK on May 24, 2011 at 05:30:58:
The hydraulic pump does not look the same as my engine. Could that be a problem?
