Re: super c sleeves
Posted by gene bender on June 01, 2011 at 18:22:46 from (207.177.56.53):
In Reply to: Re: super c sleeves posted by Red Dave on June 01, 2011 at 16:43:36:
With all the yrs gone by you never realy know if the block is original and just what bolck you do have. Its best to remove one sleeve get the measurements so you can order the correct ones its not the length its the dia where the o-ring goes as the length is all the same.
