Re: Re: Model M battery question
Posted by Alex on August 03, 2000 at 09:01:34 from (205.200.28.78):
In Reply to: Re: Model M battery question posted by The Red on August 03, 2000 at 06:22:58:
If the system wasn't converted to 12v properly then it will never charge the battery. I'm a believer in the original design, keep it at 6v with a positive ground. That way you wont get confused with the manual. Also, to go with -ve grd you would have to repolarize the generator. If it has negative grd and you connect the battery +ve to ground the ammeter will read discharge when charging, this means someone switched the wires around. Next item, high charge vs low charge you have a choice.
Post A Followup
: Re: Re: Re: Model M battery question
