How much .F-12 Oil Pressure?
Posted by F-Dean on June 01, 2011 at 20:07:36 from (75.205.58.117):
How much oil pressure is enough for a F-12 engine? My F-20s don't require much. Do F-12 engines require more?
My W-12 engine (same as a F-12 engine) produces 20 PSI most of the time (approximately 12 PSI when idling hot) but never more than 20 PSI. Is there much danger leaving it this way? Is the 20 PSI max a sign of a weak spring in the "Oil pressure box" under the filter? Should I pull the engine (a major job on a W-12) and replace the bearings? Or just enjoy it and not abuse the engine?
This is my first F-12 engine and I appreciate advice from F-12 experts.
