Re: M steering worm gear
Posted by Janicholson on June 01, 2011 at 20:54:34 from (67.72.98.45):
In Reply to: M steering worm gear posted by notjustair on June 01, 2011 at 14:24:13:
The worm is on the horizontal shaft. The sector is on the vertical. one easy way to tell is to remove the long bolt in the lower bolster flange that controls the steering limit, and see if it turns 360.
If it stops turning just after going beyond the limit, it is 1/2 sector. If it turns 360 it is a full circle gear. Turn the wheels back to engage the sector if it a 1/2 gear.
Do not drive it like this!! Jim
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
