Farmall 140 part
Posted by Michael Harrison on June 01, 2011 at 21:03:10 from (98.214.245.153):
I have a Farmall 140. Rear axle on each side has a cover for a drive that can connect via a sleeve and gear to drive a Cole fertilizer box. I am trying to find part number for the cover which is to be used when the sleeve and drive gear are in place. Presently when I have the sleeve and gear in place there is a gaping hole around them which permits dirt to get into the axle hub. I am unable to locate a part number to see if I can purchase a housing with a seal which will protect the interior of the axle hub Thanks for any help you might provide
