Re: S/A Farmall
Posted by Hayfarmer on June 02, 2011 at 07:02:29 from (71.80.197.209):
In Reply to: S/A Farmall posted by S/Bob on June 02, 2011 at 06:38:26:
When you start to pull out and it starts to die try pulling out the choke a bit. If that helps it is probably a passageway in carb that is plugged. If not check points and also timing.
