Re: Troubleshooting 41 model A
Posted by Phil Auten (TX) on August 03, 2000 at 11:02:19 from (206.175.72.226):
In Reply to: Troubleshooting 41 model A posted by Brent Wickersham on August 03, 2000 at 07:17:58:
Brent,
Make sure there isn't a big vacuum leak and that the carb is reassembled properly. If the float isn't right, there may not be gas in the bowl.
Since it was running before the carb was removed for cleaning, I'd check the carb to manifold flange to be sure it's sealed properly, then check the float setting and run a wire through all the holes in the carb to be sure there isn't a piece of rust or other solid crud blocking them.
If that doesen't get it, check the plug wires for proper installation, one or more may be crossed.
I did that once on a car, got the rotation backwards and same story, no start.
Phil
Post A Followup
: Re: Re: Troubleshooting 41 model A
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
