Re: plowing and wheel space ???
Posted by Janicholson on June 02, 2011 at 18:10:52 from (67.72.98.45):
In Reply to: plowing and wheel space ??? posted by Matt (NEIA) on June 02, 2011 at 16:26:50:
The full 16" cut of the first share is measured from the landslide to the tip of the share farthest away from the landslide. This tip should be very near the furrow when the right wheel is in the furrow plowing straight. Stopping with the plow in the ground, and digging a little will let you find it. The vertical position of that tip is also important as this makes the depth constant on each pass. Adjust the wheel spacing so the first share cuts full width. Jim
