Re: 786 axle bearing update
Posted by Owen Aaland on June 03, 2011 at 01:55:41 from (216.47.33.198):
In Reply to: 786 axle bearing update posted by Pastor Brad on June 02, 2011 at 23:46:15:
When it says to replace the cap it means to reinstall it, not to put on a new one.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
