Posted by Owen Aaland on June 03, 2011 at 04:32:18 from (216.47.33.198):
In Reply to: 686 coolant in the oil posted by Erik Dekeyser on June 03, 2011 at 04:11:24:
Look carefully around the outside of the bottom of the sleeves. It is very likely that you have an O-ring leaking. With O-rings it is not only how many hours on on the engine but also how many years since they have been changed.
Most likely you will have to remove the cylinder head and then if you are able, you can remove the sleeve and piston as an assembly. If the block and sleeve look good you could make a satisfactory repair with just replacing the O-rings.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
