Re: corrosion problem
Posted by Ellis Kinney on June 03, 2011 at 08:04:44 from (74.130.202.107):
In Reply to: corrosion problem posted by Ellis Kinney on June 02, 2011 at 18:14:35:
Jim; thanks for the reply. Due to an incredible amount of rain in northern Kentucky my barn has been extremely damp inside this spring. That is the only variable I can think of. I'll use the rubber band trick. Ellis
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
