Re: Farmall A vs Super A
Posted by Athol Carr on June 03, 2011 at 15:05:40 from (115.188.3.223):
In Reply to: Farmall A vs Super A posted by charlie M on June 03, 2011 at 12:20:40:
The Farmall Super A numbers start at 250000, there was a gap from the last of the Farmall A. The only noticeable differences are the clutch to transmission casting has the flat top to take the Touch Control unit, the engine has the pad under the magneto (distributor) to take the hydraulic pump and the steering wheel support and instrument panel is different'
