steering on 856
Posted by caterpillar guy on June 03, 2011 at 19:04:48 from (66.188.53.165):
We are having a come and go problem with the power steering on an 856. It will lag when first started then go to working in about a minute. This happens sometimes and then sometimes not. Today went to spread fertilizer and wouldn't steer so changed tractors. Went out to put in shed, to check it out further, and eventually went to working by the time I got to the shed. I pulled the flow control valve out. It has some wear on the valve body. The pressure is 2000PSI at rated speed as called for. I question the flow control valve. Any better ideas?
