My experience has been as follows. Remove all the little studs on the brake pan(cover). Pull the cotter pins on the brake spring and disconnect. Now soaking with penetrating oil and heating will help,but I had one on an H that was so rusted and siezed that we had to use brute force. I got a big pry bar that had a tappered point and we sprung the brake pan enough to get the bar in to the point where the shaft goes into the trans housing. I held the bar tight against that point and my friend hit the end of the bar with a large sledge hammer. We had to hit it several times and it finally moved and we were able to continue wiggling and prying..and we were nearly six hours from the time we started until we got it out..one of the toughest ones I ever did. I keep a set of brake pans ,shafts,shoes etc and the brass bushings that should be present where the shaft sets into the trans housing. The worst case senerio is to cut the pan off and then have access to the shaft,heat it all with the blue wrench and douse with cold water,it will come out that way too. I cleaned the hole in the trans housing with a dremel tool ,then grease if liberaly,inserted the new brass bushing and then replaced the brake pan/shaft. Those things get siezed and rusted and they are in there like they were welded. Finding a brake pan assembly for an H should not be hard to do and it shouldn't be expensive if you have to sacrifice the old one.If we were closer,I'd give you a hand and bring an extra brake pan/shaft assembly along.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
